ABS LIGHT AND TRACTION COMES ON AFTER RUNNING A FEW MINUTES AND STAYS ON UNTIL NEXT START
Jan 25, 2008 at 9:32 PM
MERLIN2021
✓Experienced Mechanic
The first step in diagnosing ABS, is get the code(s) read. This will point you in the direction of the problem part(s). Usually if you drive it to about 14mph, for a specified distance, if a problem exists in a wheel sensor or wires, it will light the ABS lamp...
