1997 Pontiac Grand Prix radiator flush
151,453 MILES • 6 CYL • 2WD • AUTOMATIC
THOMAS COOPER
I was checking the cooling system and I saw some brown sticky stuff in there. Now the question is if I get it flushed will that sticky stuff clog up my engine during the flush
Sep 17, 2009 at 1:27 AM
MMPRINCE4000
  • 8,548 POSTS
Drain the existing coolant, refill with water, run to operating temp, drain and refill with water and flush.
If using Dex-Cool, you MAY have a bad intake manifold gasket allowing oil into cooling system.
Sep 19, 2009 at 12:26 AM
