Hi, Make Sure Both Cooling Fans Come On With the ac On. Also Make Sure You Have Enough Freon In The Ac system. Look At Your Temperature Gauge, To see That It's Not Overheating. Make Sure Your Coolant Is full. Remove Radiator Cap, And Look To see That it Is full. Full Up The Coolant Bottle Also, To the Proper Level. Do This Only On a Cool Engine, Never Remove The Radiator Cap If The Engine is Hot.
Hope This Helps You,
Good Luck
Edward S.
SPONSORED LINKS
Sunday, July 25th, 2010 AT 8:33 AM
