Ok on the right side of the dash by the a/c plenum locate the blower resistor, test for power at the connector, if there is power, replace the resistor. This one has the high blower relay built into it.
Removal & Installation Disconnect negative battery cable. Remove right-side lower instrument panel insulator panel. Disconnect blower resistor connector located behind right side of dash. Remove blower resistor screws and blower resistor. To install, reverse removal procedure.
Saturday, August 2nd, 2008 AT 10:32 AM
