1997 Pontiac Grand Prix intake manifold gasket
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
KYLE78
got a 97 pont gp, today it started, then it surged and stalled out. i changed the plugs and wires, still same issue stalls out, i hear the fuel pump and have pressure. i have spark and the motor will start if you rev it real hard around 3000rpm. when it idles it stalls, have been told that this is a typical intake mainfold taking in to much air. also makes a look sucking sound almost like a cold air intake sound. does this sound like a gasket issue and what am i looking at for repair...............
Nov 17, 2009 at 8:57 AM
MMPRINCE4000
  • 8,548 POSTS
Pressure test the cooling system to verify the intake gasket is leaking, typical repair at a dealer is $700.
Nov 19, 2009 at 12:30 AM
