my grand prix,will only run for maybe 2 seconds,it cuts off like its out of fuel,the fuel filter is new,other new parts are idle air valve,mass air flow sensor,and tps sensor, when it first acted up it would crank up and run a few days then cut off again,and then it got worse,i could be driving and it would just cut oof likes there no fuel,it does it when its cold also..what do you suggest??
Mar 22, 2008 at 6:42 AM
