1997 Pontiac Grand Prix fuel pump
TONELOVE
  • 1997 PONTIAC GRAND PRIX
  • 6 CYL
  • FWD
  • 99,000 MILES
I just bought a 1997 grand prix, installed new fuel pump, the car started and ran good for about ten minutes then stalled out then I tried to restart and failed after that I then took out fuel pump tested it and it was good, checked fuse and relay it was good, check wires running to fuel pump and had no power, check for torn or burned wire there were none so could you help me out on this one?Plzzzz
Saturday, June 21st, 2008 AT 5:52 PM
MASTERTECHTIM
  • 4,750 POSTS
No power at the gray wire? Check the fuel pump relay for corrosion at the connector and replace if necessary
Sunday, June 22nd, 2008 AT 6:46 AM
TONELOVE
Do you mean pull relay out or behind the relay box
Sunday, June 22nd, 2008 AT 12:08 PM
MASTERTECHTIM
  • 4,750 POSTS
Pull out the relay and look at the contqacts and see if any are corroded
Wednesday, June 25th, 2008 AT 7:46 PM
