HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Grand Prix
Engine
Symptoms
Not Cranking Over
1997 Pontiac Grand Prix
DAKOTAH22
MEMBER
1997 PONTIAC GRAND PRIX
Engine Mechanical problem
1997 Pontiac Grand Prix 6 cyl Automatic
My car will not crank, i've replaced the coils, the coil plate and the battery. What else could be the problem?
Tuesday, March 23rd, 2010 AT 8:05 PM
MMPRINCE4000
MECHANIC
Spray starting fluid down TB and see if it runs a few seconds, if so problem is fuel.
If not problem is ignition, have ignition module tested at most autoparts stores for free.
Wednesday, March 24th, 2010 AT 8:30 AM
Please
login
or
register
to post a reply.
Related Engine Not Cranking Over Content
1997 Pontiac Grand Prix Won't Crank
Electrical Problem 1997 Pontiac Grand Prix 6 Cyl Front Wheel Drive Automatic Having A Problem With My Car, Acts Like A Low Battery...
Asked by
archemedes
1997
PONTIAC GRAND PRIX
VIDEO
Car Not Cranking? Try This | EASY
Instructional repair video
GUIDE
Starter Not Working
This guide is designed to help you identify whether the issue with your non-working starter motor is due to an electrical problem or a fault within the starter motor itself...
1997 Pontiac Grand Prix Takes A While To Turn Over
My Grand Prix Takes A While To Start. When I Start It The Starter Engages Immediately And Sounds Strong. To Be Safe I Took It Off And Had...
Asked by
Brad Eadens
1997
PONTIAC GRAND PRIX
No Crank Starter Good
I The Se Model. The Starter Is Good But Still Will Not Crank Over. Battery Is Also Good.
Asked by
Katrina Holston
1 IMAGE
1997
PONTIAC GRAND PRIX
Starter Sometimes (seems To Be Getting Worse) Will Not...
My Cars Starter Sometimes (seems To Be Getting Worse) Will Not Work When Trying To Start The Car. It Is A New Starter And The Car Has A New...
Asked by
codymartin
1 ANSWER
1 IMAGE
1997
PONTIAC GRAND PRIX
Pontiac Grand Prix Gt
My Car Stalled Out After I Turned The Blinker On, The Gauges Went Crazy And It Quit, I Restarted It And Used The Blinker And Again The...
Asked by
babymaddy11699
1 IMAGE
1997
PONTIAC GRAND PRIX
VIEW MORE
Battery Replacement Video
Starter Motor Replacement
