the car is a gtp when u start the car it starts n then in runs for bout 5 secs n shuts off is that a sensor or the fuel pump
Mar 4, 2008 at 10:08 AM
BLACKOP555
✓Experienced Mechanic
will it fire right up after it dies out? or does it have to sit for few hours.
if you keep spraying starting fluid down the throttle body while its running does it keep running till you stop giving it fluid?
Mar 4, 2008 at 12:32 PM
