Hello, your vss might be causing a problem? You'd need to check the circuits. I can't tell if there might be others?
Can you check for codes, some of the national brand autostores will check codes for free.
SPONSORED LINKS
Tuesday, February 10th, 2009 AT 8:23 AM
