Saturday, December 13th, 2008 AT 10:31 PM
’97 Pontiac GP GTP Transmission Problem - Today while stopped at a traffic light my car would not move when the light turned green. It was as if the transmission was in neutral. I tried shifting through the gears with no response. I turned the car off and called for a tow truck. While waiting for the tow truck I restarted the car and the trans worked normally. I took off and moments later the trans started slipping again. I pulled over, turned the car off, waited a few moments and then restarted the car - the trans worked normally, but again only momentarily. This condition keeps repeating. Seems to me like an electrical malfunction or some valve sticking. Any ideas/suggestions?
