Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Grand Prix
Engine
Symptoms
Coolant In Oil
1996 Pontiac Grand Prix coolant
1996 PONTIAC GRAND PRIX
149,000 MILES • 4 CYL • 2WD • AUTOMATIC
SARGE07
MEMBER
1 POST
The coolant is mixing with the oil. What needs replaced?
Jan 5, 2010 at 1:40 AM
MMPRINCE4000
Experienced Mechanic
If you have coolant in oil, it is either the headgasket or intake manifold gasket.
Perform a compression test to check the headgasket.
Get this repaired ASAP and do not drive the car, coolant in oil will strip the oil film off the main bearings and can cause severe engine damage.
Jan 5, 2010 at 10:23 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
