You will need to take it to a shop that has a chassis scanner, to read the ABS codes.
Could be as simple as a wheel sensor that has worked loose, the the scanner will tell you.
While most autoparts stores will read codes, they can only read "P" codes or powertrain codes. A chassis scanner will read "C" codes (ABS).
SPONSORED LINKS
Monday, November 10th, 2008 AT 10:02 AM
