1995 Pontiac Grand Prix Replace driver side window motor
84,000 MILES • 6 CYL • 2WD • AUTOMATIC
PBIDWELL
Just cannot see how to remove the widow motor . What holds it inside the door ?There are not any bolts that I can see to remove. Please can you help me on how to remove the motor to replace it? Thanks for any help that you can give to me.
Paul
May 26, 2008 at 6:17 PM
MASTERTECHTIM
  • 4,750 POSTS
the whole window regulator assembly must be removed in one piece. you need to drill out the big rivets holding it in. kind of tricky job.
May 26, 2008 at 10:34 PM
