Make sure the cooling fans are working, turn on AC and fans should run (at slower speed), if not then fan motor, fuse, fan switch or relay.
Have cooling system pressure tested.
Ask mechanic to spell the part he thinks is bad. Platinum is used as a catalyst in the convertor.
SPONSORED LINKS
Wednesday, March 11th, 2009 AT 8:59 AM
