Engine Mechanical problem
1995 Pontiac Grand Prix 6 cyl Two Wheel Drive Automatic >100K miles
I have a 95 Pontiac Grand Prix SE with a steady coolant loss. I replaced an intake manifold gaskets but it did not solve the problem. The car continues to loose the coolant, although at much slower pace (1 cup a month). However, I can see the sludge build-up on the passenger corner of the rear head (the area of cylinder #1), and, sometimes a few drops of the green coolant could be seen there in the morning. Also, it seems that the intake gaskets should be replaced again since the engine leaks oil from the S-shaped area of the intake where I placed some sealant. I described the above symptoms in my previous post and got excellent answers (thank you, 2carpros experts). So I decided to remove the heads, send them for resurfacing and replace the gaskets. Since I already did the intake job, I hope that I will be able to remove the heads as well. However, I have some questions regarding this repair:
1) It seems that the engine supporting bracket on the right front should be removed. The bracket is bolted to the A/C compressor. Does it mean that I need to disconnect and remove the compressor?
2) I checked both heads visually. The front (left?)head seems to be OK. May I remove the leaky (rear, right) head only?
3) How difficult is to disconnect the exhaust manifold?
Thank you,
Anton.
Thank you,
Anton.
Jan 3, 2010 at 4:38 AM
