1995 Pontiac Grand Prix engine quits running
STEPHEN PETERS
  • 1995 PONTIAC GRAND PRIX
Engine Performance problem
1995 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic
My 1995 Pontiac Grand Prix starts when cold and runs good. During cold weather I did not have the following problem. After the car is driven and warmed up and turned off for a half hour when restarting it starts and acts like it is going to run then it will begins missing and quits running. It then takes approximately two hours from the initial stopping time and it will start and run perfectly. It has not done this if the car is restarted within 5-10 minutes of the initial starting time. The warmer the outside tempeture it seems the worse the problem
Sunday, March 14th, 2010 AT 4:41 PM
Hi Stephen Peters, Welcome to 2carpros and TY for the donation
Next time it acts up do below don't wait. Check the fuel pressure if its within specs and clean out the idle air control valve and test the throttle position and manifold absolute pressure sensor.
Sunday, March 14th, 2010 AT 5:11 PM
