No Start When The Security Light Flashes?
1994 PONTIAC GRAND PRIX
175,000 MILES • 6 CYL • FWD • AUTOMATIC
CMIL5991
Some times the word SECURITY in yellow flashes when I try to start my car. The car will not start when this flashes. When I try to restart the car the light will not flash and then the car starts. Some times it takes a few minutes for the light to stop flashing. Could the ignition key be worn out???
Mar 24, 2009 at 6:44 PM
BMRFIXIT
  • 19,053 POSTS
The security system wiring inside the steering column broken you can by pass the system by using resisters use an ohm meter measure the resister on the key radio shake or similar stores should have the resisters you can connect two or more to get what you need locate the wiring under steering above brake paddle wiring harness orange tube with two small white wires in it cut them and place the resister in between need to know more and how let me know.
Mar 24, 2009 at 11:33 PM
CMIL5991
Thank You!!!!
Mar 25, 2009 at 8:43 AM
