1994 Pontiac Grand Prix heat
FOZZIEMOTTOE
  • 1994 PONTIAC GRAND PRIX
Heater problem
1994 Pontiac Grand Prix 6 cyl Two Wheel Drive Automatic
needs to be above approx 1500 rpm, s to blow hot air doesnt over heat runs about 200 on temp gauge has 195000 miles in two months I lose aproxx quart of coolant
Saturday, December 26th, 2009 AT 11:08 AM
JDL
  • 16,098 POSTS
Welcome to the forum, at normal idle, are the heater hoses hot? Maybe the heater core needs to be flushed? The air flow volumn is close to the same, idle or off idle, just not hot? The water pump probably runs faster at higher idle, so the flow through the heater core is faster. Just a thought.
Saturday, December 26th, 2009 AT 11:22 AM
