1994 Pontiac Grand Prix Fuel Injectors
162,000 MILES • 6 CYL • FWD • AUTOMATIC
SUKASAROTH
I bought a 1994 Pontiac Grand Prix Special Edition Coupe 3 days ago and I drove it for about 2 hours. I took it to my dads house to give it a bath and i sprayed under the hood around the edges to clean out the gunk from leaves. After I finished I drove about a half mile down the road after the car started up just fine. At a stop light the car just stopped. It would crank over yet no fire. The gas gauge didnt work so I thought it was out of fuel. I push it to the gas station on the corner and i find out the tank was almost full. I get the engine to start for about 3 minutes and it died again. Since I cannot get it started. It starts on ether but thats it. I changed the fuel filter and I get fuel pressure on the rails so it is not the fuel pump. I believe it has something to do with the injectors but I dont know what would cause them not to pump fuel into the cylinders. I tried replacing fuses but nothing seems to work. Anything I might have missed? Thanks for the help!
Jun 7, 2010 at 12:25 PM
  • 75,988 POSTS
Use a noid lite on the injector harness -crank engine over it should be flashing if not check for power on the harness if okay the injector/s ground drivers on the computer is defective-if its flashin but injector is not spraying fuel test the injector solenoid resistances
Jun 7, 2010 at 12:51 PM
SUKASAROTH
got the noid light but i cant find the injector harness. is it easily accessible?
Jun 8, 2010 at 5:49 AM
