1994 Pontiac Grand Prix Engine Overheat
AMOR1968
  • 1994 PONTIAC GRAND PRIX
Engine Cooling problem
1994 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic
The engine keeps over heating. The car has a new radiator, new water pump, new thermostat and a new radiator cap. What else can it be?
Monday, January 25th, 2010 AT 6:51 PM
MMPRINCE4000
  • 8,548 POSTS
If you do not see any coolant leaking on ground, then cooling system could be blocked, cooling fan not working.
Worst case would be a bad headgasket.
Have a compression test performed, if OK, the drain and flush cooling system and make sure cooling fan is working.
Wednesday, January 27th, 2010 AT 7:53 AM
