what is the head torque, valve torque, and lower intake torque on this motor?
Thursday, June 17th, 2010 AT 11:00 AM
HMAC300
MECHANIC
To torque the heads the bolts have to be replaced and torqued to 60nm first step then 95 degrees using a degree wheel. They have to be torqued starting in the center and working outwards. The inlet bolts have to be torques 13nm (115 inch lbs) in the same sequence on the lower and 25 nm (18 ft lbs) on the top manifold.
