1993 Pontiac Grand Prix erotic misses an jerks
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
RATATAT
I recently been having a bad miss problem,been to plenty mechanics an i also work on cars but...I can start the car an it idles fine forless than a min then misses an jerks.It has a code(42 after I reset the ECM) misses real bad in sperts! I've replaced plugs,Iat sensor,crank sensor,ign module,map sensor,air idle sensor and all 3 coil packs,fuel filter and my fuel pressures at 42psi(ign key on)now wont even start..but it was pooting out of the exaust an once out the intake.. Need help Bad!!! (Lost without a cause).
Nov 12, 2009 at 11:38 AM
Engine misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Nov 12, 2009 at 12:16 PM
