1992 Pontiac Grand Prix Turn Signal Flasher Fix
KITKAT822000
My turn signal flasher broke and I want to know where it is located so I can fix it. Please help
Feb 12, 2006 at 3:43 AM
MVANNESSJR
  • 223 POSTS
The turn signal flasher is behind the steering column bracket. Behind Right Of Brake Pedal Support. Check out the images (Below). Please let us know if you need anything else to get the problem fixed.
Feb 12, 2006 at 5:13 AM
Suggested Repair
Locate the turn signal flasher behind the steering column bracket, to the right of the brake pedal support, and replace the broken flasher.
Conversation Summary
The owner of a 1992 Pontiac Grand Prix asked where the broken turn signal flasher is located. The expert said it is behind the steering column bracket, to the right of the brake pedal support.
