1991 Pontiac Grand Prix timing belt on a 3.4L
99,986 MILES • 6 CYL • FWD • AUTOMATIC
MOTOKING_1990
  • 10 POSTS
I recently asked the question on why my car wouldn't start and I figured it out. I stripped the timing belt out on my 91 Grand Prix GTP 3.4L and my question now is, is the early 90s 3.4L v6 an inteference engine? I have talked to a few others online and one said it is but three others said the years 91 to 95 where not considered intereference motors. I would have done a leak down test but I do not have the tool to screw into the spark plug hole. But I will do a compression test to see if i bent a valve but til then i need to know if the engine is interference or not any information would be greatly appriciated
Thank you, Greg
Sep 22, 2010 at 2:09 AM
WRENCHTECH
  • 20,760 POSTS
Alldata lists that engine as a "freewheeling" engine so you shouldn't have any damage. I have seen a few broken belts on those and never valve damage.
I want to warn you though. Do not attempt to change this yourself without the special tool kit. It is a complicated timing procedure too. Many techs have a lot of problems with it because the banks are timed 180 out of each other.
Sep 22, 2010 at 2:16 AM
MOTOKING_1990
  • 10 POSTS
Thank you for responding so quickly. I live with an ase certified gm auto tech but he is out of town and i cannot get ahold of him. He uses alldata too thanks again
Greg
Sep 22, 2010 at 2:25 AM
