1991 Pontiac Grand Prix no power
1991 PONTIAC GRAND PRIX
180,000 MILES • 6 CYL • FWD • AUTOMATIC
ROGER MONG
the car is stating hard, lost power, jerks at steady speeds, dies when really cord, i have checked for vac. leaks checked the spark plugs one had a black carbon build up not real bad i ran injector cleaner in it
Feb 14, 2010 at 9:03 AM
Inspect and test all the following listed below:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Cap and rotor
Note:If it doesn't apply disregard.
Feb 14, 2010 at 9:26 AM
