It started 2 cut-off while I was driving but when I looked at the RPMs it was idling but not in gear. Once I put it in neutral it cut all the way off and start back up fine and jump back in gear once in drive.
Then my battery totally died WHILE I was driving home from work (I noticed the lights getting dimmer and dimmer as I drove then it jus stopped when I stopped) and I was stuck for about 2 hours then it miraculously started back up and I made it home.
The next day it stalled in front of my house and refused to start. I got it started and it cut-off at least 8-10 times on my way around the block to park it.
I went to start it and it would run for about 30sec. To a minute, lights would dim, and then it made a weird sound and then cut-off.
I replaced the BATTERY and the FUEL FILTER on it and it does the same thing still.
DOES ANYONE KNOW WHAT THE PROBLEM IS AND HOW MUCH IT MAY COST?
SPONSORED LINKS
Monday, February 23rd, 2009 AT 12:46 AM
