How do you remove the front seats for this car. They are power.
Jul 31, 2008 at 9:17 AM
MERLIN2021
✓Experienced Mechanic
There are 4 bolts, one at each corner, on the rails, but remove the negative battery cable first.
Jul 31, 2008 at 9:21 AM
STYKS1987
MEMBER
will these bolts remove the whole assembly? or just the seat. I have found two bolts holding the seat down but the rest is held down by riveted type bolts.
Thanks for your help!
Jul 31, 2008 at 9:29 AM
MERLIN2021
Do the rivets have a star shape in the middle? If so they are Torx head bolts, it will be anywhere from T-45 to T 60... and they will unscrew like a normal bolt.
Jul 31, 2008 at 10:12 AM
