car womt start good spark and fuel pressure new plugs wires coilpacks and ecm any thoughts
Mar 11, 2009 at 9:34 AM
✓Experienced Mechanic
We got spark and fuel pressure-my question here is it the correct fuel pressure EFI system don't like low pressure and also are the injector/s pulsing
Spark and Fuel pressure and injectors are okay-Check the valve and ignition timing report back with some results
Mar 11, 2009 at 10:15 AM
BILLS GP
MEMBER
did all that but here is something funny i hit the rearbumber and it started ran for 2 hours shut off restart left alone for 1 hour will not restart tried bumber agin no luck
Mar 11, 2009 at 1:05 PM
Sounds like the fuel pump is on its way out
Mar 11, 2009 at 3:34 PM
BILLS GP
MEMBER
[quote:45d1f47fd1="rasmataz"]Sounds like the fuel pump is on its way out[/quote:45d1f47fd1] do i need to drop the tank or can i go threw the trunk
Mar 12, 2009 at 12:47 AM
No too familiar with this model might want to check it for an access panel under the seat or the trunk if not it has to come down.
Mar 12, 2009 at 5:40 AM
