car womt start good spark and fuel pressure new plugs wires coilpacks and ecm any thoughts
Mar 11, 2009 at 9:34 AM
✓Experienced Mechanic
We got spark and fuel pressure-my question here is it the correct fuel pressure EFI system don't like low pressure and also are the injector/s pulsing
Spark and Fuel pressure and injectors are okay-Check the valve and ignition timing report back with some results
Mar 11, 2009 at 10:15 AM
BILLS GP
MEMBER
did all that but here is something funny i hit the rearbumber and it started ran for 2 hours shut off restart left alone for 1 hour will not restart tried bumber agin no luck
Mar 11, 2009 at 1:05 PM
Sounds like the fuel pump is on its way out
Mar 11, 2009 at 3:34 PM
BILLS GP
MEMBER
[quote:45d1f47fd1="rasmataz"]Sounds like the fuel pump is on its way out[/quote:45d1f47fd1] do i need to drop the tank or can i go threw the trunk
Mar 12, 2009 at 12:47 AM
No too familiar with this model might want to check it for an access panel under the seat or the trunk if not it has to come down.
