1985 Pontiac Grand Prix no spark!
1985 PONTIAC GRAND PRIX
70,000 MILES • V8 • 2WD • AUTOMATIC
M_RUTZEN1
My GP was running great and I put into nuetral last year and revved the engine to scare my brother. I parked the car and it wouldnt start again. I replaced the ignition coil because that was my first idea(and it was the original one) but no good. There was also a really old alarm system there I disconected a while ago, but my car worked fine after then. I FORGOT TO ADD that when I turn the key in my car(not crank it) my carb has a clicking sound coming from under it or inside(eletrical sound kind of) that goes off after about 7 seconds. I tested for spark in my plugs and there is none. any ideas?? I am willing to try everything I just need some input! I am really lost and I just finished straightening the body and I CANT EVEN DRIVE IT TO THE BOOTH! Please help.
Matt Rutzen
Feb 10, 2009 at 7:13 AM
JDL
  • 16,098 POSTS
Is the coil in the cap on your vehicle? Have you tested the coil primary circuits? If the coil is in the cap or even mounted remotely, the B+ terminal usually goes hot when you turn on the key. If you use a testlite on the ground or tach terminal, the lite should pulse with the engine cranking. If there is a pulse, check the rotor, no pulse, check the pickup coil or ignition module. I don't have a wiring diagram for your vehicle.
Feb 10, 2009 at 7:42 AM
M_RUTZEN1
[quote:b41dc69843="jdl123"]Is the coil in the cap on your vehicle? Have you tested the coil primary circuits? If the coil is in the cap or even mounted remotely, the B+ terminal usually goes hot when you turn on the key. If you use a testlite on the ground or tach terminal, the lite should pulse with the engine cranking. If there is a pulse, check the rotor, no pulse, check the pickup coil or ignition module. I don't have a wiring diagram for your vehicle.[/quote:b41dc69843]
the coil is in the cap. I tested the coil circuit and it was good. Ill go over those things . The rotor is about 6 months old. thanks for the help, going to try it right now
Feb 10, 2009 at 8:05 AM
