Firing order?
JONNYB88
  • 2007 PONTIAC GRAND PRIX
  • 120,000 MILES
Firing sequence for Pontiac Grand Prix
Tuesday, November 6th, 2012 AT 7:18 PM
Wednesday, November 7th, 2012 AT 6:48 AM
JONNYB88
Thanks guys that's what I needed
Wednesday, November 7th, 2012 AT 9:16 PM
TERRYWAYNE2
  • 2005 PONTIAC GRAND PRIX
Need firing order diagram front and side view. It is a 3.8 xp Grand Prix. I think I crossed wires.
Monday, March 8th, 2021 AT 6:11 PM (Merged)
  • 110,037 POSTS
Here is the engine spark plug firing order. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Cheers
REDNECK0819
  • 8 POSTS
  • 3.8L
  • 6 CYL
  • 114,000 MILES
Is there a difference in the firing order of the 3800 between a VIN:K and my old ladies that is a VIN:2? The coil packs from top to bottom run 6-3-2-5-4-1. Just trying to make sure they didn't get cross wired somehow. Thank you
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Yes, both the vin K and vin 2 firing order on the 3.8L motor is exactly the same. I've attached pictures below. Hope this helps and thanks for using 2CarPros.
CIRACING13
  • 1996 PONTIAC GRAND PRIX
I need the firing order diagram for the 3.1L v6
JDL
  • 16,098 POSTS
Hi, welcome to the forum. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
https://www.2carpros.com/forum/automotive_pictures/170934_grand_prix_firing_order_2.jpg
SARAH&GREG
  • 1995 PONTIAC GRAND PRIX
  • 6 CYL
  • FWD
  • 164,000 MILES
What is the fireing order on a pontiac grand prix gtp? It has the 3.4 dohc motor. My car starts up an revse up an shuts off.
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_grand_prix_firing_order_1.jpg
You treat a start and die the same as a no start. You try to out what your losing. Spark-- fuel, don't guess about the fuel, use a gage and check pressure, key on and then after it dies. any codes?
SHOOTOUTFAN
  • 1985 PONTIAC GRAND PRIX
  • 6 CYL
  • 142,345 MILES
Whats is the location of the number 1 clynder and the firing order and the location each wire goes on the distributer?
BMRFIXIT
  • 19,053 POSTS
Hope that clear things for you let me know
https://www.2carpros.com/forum/automotive_pictures/99387_grand_prixv6__firing_order_1.jpg
