1981 Pontiac Grand Prix Installing fuel pump
SANDYPED
Engine Mechanical problem
1981 Pontiac Grand Prix V8 Two Wheel Drive Automatic
When I screw in the two bolts to hold the pump to the engine/ block the top part of the pump does not seal tight leaves an 1/8 th inch gap when the bolts are tight.
Mar 2, 2010 at 7:33 AM
BLACKOP555
  • 10,386 POSTS
use a straight edge across the matings surfaces of the pump and the engien block mounting flange for the pump. make sure they are both flat. the one that is warped needs to be replaced.
why was old pump changed? is it a high quallity new one?
Mar 2, 2010 at 9:57 AM
SANDYPED
HI guys,
I have figured it out. Yanno the piece that moves like an arm or something, don't know what it is called. It is inside the pump. looks like some part of a water pump that you would stand and push up and down on??? Make sense? LOL Anyway, THAT was pushing against something in the engine/block whatever, in the hole there was something it was pushing up against. So duh! Now I figured it out I have yet to actually screw it back on tho, after trying to for so long, having to take it off and put it on a few times, my shoulders and arms are too tired today to be able to push/hold the pump up while I fit the bolts into their holes and tighten them!! LOL
as you can tell I am a newbie, learn as I go!! Thank you for your help!
Mar 2, 2010 at 1:56 PM
BLACKOP555
  • 10,386 POSTS
easy to overlook stuff like that! sounds like a legitamate mistake. glad to hear you have found out your problem. if you have any other questions dont hesitate to post back!
Mar 4, 2010 at 6:21 AM
