where is the knock sensor
B_DOBER
Hi. I have a 1996 grand am se (3.1 SFI V6) and all i want to know is where the knock sensor is located on the engine. I got a code for low voltage on knock sensor.
Also wondering if an 3.1V6 from 1995 has a knock sensor and if so, is it interchangeable with the 1996 3.1V6 engine.
Oct 1, 2007 at 9:32 AM
FAIRRACING31
  • 150 POSTS
Your knock sensor is located on the front (radiator) side of the block above the oil filter. Don't know if a 1995 knock sensor will work on a 1996. You are better off to replace it with a new one.
Oct 1, 2007 at 10:14 AM
MERLIN2021
  • 17,250 POSTS
On the left front of the engine, Look for the letter H in the diagram. I don't think there will interchange, 95 is OBD I 96 is OBD II. Different computer systems...
https://images.2carpros.com/forum/automotive_pictures/62217_knock_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_30961_mitchell_2_41.jpg
Oct 1, 2007 at 10:17 AM
