Vehicle wont start/new starter and good battery
BDAWGG91
I have a 1994 Grand Am with aprox..150,000 miles and a 3.1 liter v6.i replaced the starter and sloeniod,and made sure the battery was good,and now it will click when I try to start it.but only once.also now i have no interior lights or radio,yet my headlights work fine.even my auto trunk switch won't work and the battery is fully charged and tested.prior to rplacing the starter and solenoid,I full use of my radio and in side lighting.and as I said before now when the ignition is turned on to attempt to start the vehicle,it just goes click once and that is it.Any help would be appreciated as i am tired of walking to work.
Apr 19, 2007 at 2:51 PM
  • 75,988 POSTS
Check the ignition switch-turn key to start position check for power at the little wire terminal at the solenoid-no power check the NSS-no power replace the Ig switch.
Apr 19, 2007 at 6:04 PM
