1999 Pontiac Grand Am Starts Then Dies
If you got fuel and spark and refuses to start next step is to check valve and ignition timing-
Suggested Repair
When it dies, check for spark by grounding a plug wire while cranking. If spark is present, listen for injector clicking to confirm fuel. If there is fuel but no spark, continue troubleshooting the ignition system. If both fuel and spark are present and it still will not stay running, check valve and ignition timing.
Conversation Summary
A 1999 Pontiac Grand Am with about 88,000 miles starts then dies immediately, and the automatic headlights and instrument lights sometimes fail to come on. Fuses checked fine, and it briefly started on level ground before stalling again. The expert advised checking spark right after it dies, then listening for injector clicking to confirm fuel, troubleshooting the ignition system if spark is missing, and checking valve and ignition timing if both fuel and spark are present.
