Well I did what you saids and it was fine.5 volts. Put car back on scanner. Things just didnt add up. 15 a/f ratio. Still smells rich. I said f it went back to basics and put that brand new scanner in the box and pulled out my vacum gauge and found thatI had super low vacum witch I alway suspected motor didnt reallly respond to any idle change removing vacum plug ect, the 1 egr selinod was stuck open. Scanner said off. I new no codes its mechanical.
Thans for your help Bobby
SPONSORED LINKS
Friday, December 15th, 2006 AT 6:50 AM
