Resetting the oil Sensor
PONTIAC GRAND AM
BULLFROG1981
I have a 2005 Pontiac Grand Am, 80.000, 3.4L.
I changed the oil, How do I reset the sensor?
Nov 20, 2007 at 11:38 AM
DAN V
im trying to remember im pretty sure youturn the key in the on position but dont start it then pump the gas pedal 3 times or you turn the key on & off 3 times
Nov 20, 2007 at 11:58 AM
QUADRACER2157
There are 2 ways to reset the oil light, (key in the on position not started, then push the gas 3 times to the floor) or (take off the panel between the door where the fuses are, and look for a fuse looking button that says reset then turn the key to the on position then hold in the button until you see the oil light flash or hear a beep from the speakers).
Nov 24, 2007 at 12:49 PM
