Replacing Front Brake Pads
PONTIAC GRAND AM
KYLEARCH
2002 Pontiac Grand Am, roughly 95000 miles, 4 cyl.
I am trying to replace the front brake pads on my car but when I get to the point of removing the calipers, the manual says to pivot them up but they wont move more than a 1/4 inch or so, there seems to be something holding it down. I removed the lower bolt and loosened the upper bolt so it *should* be free to move, what am I missing?
Mar 8, 2007 at 9:05 AM
KYLEARCH
Well it turns out I just wasnt applying pressure in the correct spot or in the correct amount, with both bolts off I used my tire iron which has a flat blade on one end to pry the caliper off at the top, it was actually quite easy once I figured it out.
Total time for brake job? First wheel 2 hours, second wheel 20 minutes...goes to show, it helps to know what you are doing.
Mar 8, 2007 at 10:16 AM
BOOTDOG
  • 665 POSTS
the best way to learn is with hands on. i'm glad it worked out.
Mar 8, 2007 at 10:34 AM
