ran low on gas and now will not start
SKIDD
2004 Pontiac Grand AM, automatic, 78000 miles, 4 cylinder, 2.2, my car ran low on gas and now will not start. it was parked on slight decline (with frt end pointed down slightly). I added some gas and still will not crank. Thought it may have been the battery but it still would not start after been jumped off. What can/should I do to get it started again? Thank you very much for your help.
Aug 30, 2007 at 12:13 PM
  • 75,988 POSTS
[quote:bf58c30d78="skidd"]2004 Pontiac Grand AM, automatic, 78000 miles, 4 cylinder, 2.2, my car ran low on gas and now will not start. it was parked on slight decline (with frt end pointed down slightly). I added some gas and still will not crank. Thought it may have been the battery but it still would not start after been jumped off. What can/should I do to get it started again? Thank you very much for your help.[/quote:bf58c30d78]
When you turn key to On, do you hear the fuel pump for a few secs-if so find the fuel filter and replace it, then check the fuel pressure.
Sep 1, 2007 at 10:25 AM
