Pontiac Grand Am 2.4L Automatic/92,000 miles...No problem starting , or accelerating slowly..Getting a missfire when accelerating hard to get into traffic, or on freeway at low RPM`s.I had it in shop and they were stumped as well as i am. I replaced the fallowing in order. Crank Shaft Position Sensor, Spark Plugs with AC delco PLatinum, Plug wires, both coil packs and housing, Fuel pump , fuel filter, Intake temp sensor, Oxygen sensor, ECU diagnosed and was good, all fuel injectors were ticking. I also cleaned the intake with with carb and chocke cleaner after all these were replaced(was verry filthy) and then replace the plugs once more. It got a lil better but not much. Please help me and give me your insight. I have been spending to much money on the little stuff and just want the problem fix.. Thank you !
SPONSORED LINKS
Wednesday, May 23rd, 2007 AT 1:06 PM
