how do you remove the left rear door panel on a 2000 pontiac grand am to fix the window. the motor works.
Jan 27, 2007 at 4:38 AM
SERVICE WRITER
✓Experienced Mechanic
Probably gonna need a regulator, may be available aftermarket. I can't help on the panel. Most are held in with a plastic clip that can be pulled out, some you need to lift up on. I'm sure the engineers have changed the answers to those questons already.
