Is it possible to manually adjust the idle w/ fuel injection
PONTIAC GRAND AM
MISHKAM
Is it possible to manually adjust the idle w/ fuel injection in a 91 Grand am?
Feb 16, 2007 at 12:02 AM
MMPRINCE3000
  • 133 POSTS
Yes it is possible. However it is (almost) never a good idea. Generally the throttle plate adjusting screw is sealed. It is sealed because if the idle is high it is usually a vaccum leak and adjusting the screw will only mask the problem, and can cause more damage by causing a lean condition.
Unless you had a backfire that bent the throttle plate, I would not touch the adjusting screw. The throttle body may be clogged up from the EGR or the IAC may not be working properly.
Feb 16, 2007 at 4:07 AM
MISHKAM
Its actually idling just a tad low while in drive. Which is causing a vibration at low end idle.
Feb 16, 2007 at 7:30 AM
MMPRINCE3000
  • 133 POSTS
[quote:005bf92c43="Mishkam"]Its actually idling just a tad low while in drive. Which is causing a vibration at low end idle.[/quote:005bf92c43]
Then I would check the timing first. It may also be the throttle body plate is clogged up from EGR soot or the IAC passage is clogged.
Feb 25, 2007 at 9:56 PM
