1997 Pontiac Grand Am Misfire
SANITY2LOSE
97 Pontiac Grand Am 2.4 L 130K Miles
The car misfires, but there are no codes in the computer. misses when taking off (under load) and when at idle i can hear it missing in the exhaust. When starting up in the morning, often it will lose all power like my foot is not on the pedal at all and then correct and is fine until it starts skipping. Seems like the skipping under load gets worse the hotter the engine gets. its vital to note that it does not miss all the time and seems to be ramdom, but always worse when engine goes above the normal middle-of-the-gauge temp.
I've replaced the coil housing, done a complete tune up, checked fuel injectors, checked fuel pressure, and just gone around in circles with this thing. the only things that i can think of that are left are the coils (there are two) and the o2 sensors. but if its the o2 sensors i would have had a check engine light and a code. maybe i just answered my own question, but just wondering what else it could be. any suggestions??
Sep 27, 2007 at 5:47 PM
  • 75,988 POSTS
The OBD2 system CEL might not be lit or flashing but I'll go ahead and scanned it for code/s-probably it might come up with something.
You can still have a problem with the engine management without the CEL light being lit.
On your case-I'll check the throttle position and Load/MAP sensor for a start. Checks out -check the fuel pressure.
Sep 27, 2007 at 7:14 PM
Suggested Repair
Scan for stored codes even if the check engine light is off. Check the throttle position sensor and MAP/load sensor first, then recheck fuel pressure if those test good.
Conversation Summary
A 1997 Pontiac Grand Am 2.4L with 130,000 miles misfires randomly under load and at idle, with no stored codes. Power can drop briefly on cold start, and the miss worsens as the engine gets hotter. The owner replaced the coil housing, performed a tune-up, and checked the injectors and fuel pressure. The expert advised scanning for codes anyway, then checking the throttle position sensor and MAP/load sensor, followed by fuel pressure if those check out.
