Ok, an update on this problem.
The battery was dead so I charged it for 8 hours, the car will start and run, until it reaches 130 degrees. I asked a local parts person if he had ever heard of this type of problem, he recommended the Nuetral Safety Switch. The car is an automatic 6 cylinder. He said the switch is designed to shut the engine down when the car reaches a certain temperature but it shouldn't be 130 it should be almost double that. Has anybody else heard or had this problem.
Thank you,
Jeff
diverdad84@yahoo. Com
SPONSORED LINKS
Wednesday, September 5th, 2007 AT 1:25 PM
