1992 Pontiac Grand Am Dash Lights Out
MFERK_69
hi my friend has a 1992 pontiac grand am and it has a 2.5L engine and probably about 150,000 miles on it and the dashlights are completly out and he said it all of a sudden went out and we checked the headlight switch and the fuses what could be possibly wrong with it? one more thing i have a 1991 chevy cavalier andit has 166,000 miles on it and has 2.2 Liter when i turn on my right turn signal the headlights sometimes goes out but they come baqck on quickly when the blinker goes back into the original position. but only does it once in a while. thank you
Feb 11, 2007 at 4:32 PM
2CARPRO JACK
  • 11,533 POSTS
Pontiac- check the dimmer part of th eswitch,not just the main light switch
Chevy- Turn signals and h-lights are on same lever? do both lights dim or just one? If one then check th egrounds in that corner of the car. Seen many combo levers rub the wiring just inside the column
Feb 11, 2007 at 11:55 PM
Suggested Repair
On the 1992 Pontiac Grand Am, check the dimmer portion of the headlight switch, not only the main switch. On the 1991 Chevy Cavalier, confirm whether the turn signals and headlights share the same lever and whether one or both headlights go out; if only one side is affected, check the grounds in that corner and inspect the combination lever for wiring wear inside the steering column.
Conversation Summary
A 1992 Pontiac Grand Am with a 2.5L engine suddenly lost all dash lights after the headlight switch and fuses were checked. The expert advised checking the dimmer part of the switch. Separately, a 1991 Chevy Cavalier with a 2.2L engine sometimes loses its headlights briefly when the right turn signal is used. The expert asked whether both lights are affected and suggested checking corner grounds or wiring rubbed by the combination lever inside the column.
