If it is a head or head gasket problem, where antifreeze is in the engine because of this, start the vehicle, let it idle, look at the tail pipe, if it has white smoke, then that means it could be this problem, but if you are losing that much, next thing would be to look at the water pump leaks through the weep hole, no signs of water there, take the belt off to the water pump and do a wiggle test on the pulley, if it wobbles, then you need a new pump, if that dont work, it may be the thermostat is not opening correctly and it is under back pressure and steaming out.
Wednesday, July 29th, 2020 AT 10:15 AM
