Air Fan Not Working
MYPETTIGER
The fan to circulate air inside my 2000 Grand Am has started to die and will only kick on when the fan is turned to 5....anyone have the same problem and what can I do? Is it a fuse that I need to change or replace the fan motor?
Thanks
Gare
Jun 27, 2007 at 1:17 AM
SC1 RACING
  • 117 POSTS
local parts store will have part you need. the fan resistor is faulty. no big deal to replace. ussally 10.00 and 2 screws and 1 wire plug. when your resistor shorts out it will only work on high speed.
Jun 27, 2007 at 3:22 AM
