A/C BFC Compressor Clutch fuse
CPARRISH
on my 2004 grand am gt, my A/C BFC fuse keeps blowing. This fuse goes to the Compressor Clutch relay then to the compressor clutch. It has been blowing as soon as I turn the blower motor on whether the a/c is on or not. I thought it COULD be a bad relay( hoping), I changed with another relay that was exactly the same and it seemed to work for a while. It didn't blow when i turned the blower on or the a/c. I went on a distance trip 2hrs there, 145 back. It worked fine on the way there, but on the way back it blew. When it blows the blower works fine, the a/c light stays on, it just blows "vent air" though. Then it blew again as soon as I put a new fuse in and turn the blower on.
Anyone know what is going on? Is the Comp Clutch jsut back or is it something else? Thanks
Chris
Aug 11, 2006 at 6:31 AM
MIKEYBDMAN
  • 623 POSTS
[quote:27ce57e9c4="cparrish"]on my 2004 grand am gt, my A/C BFC fuse keeps blowing. This fuse goes to the Compressor Clutch relay then to the compressor clutch. It has been blowing as soon as I turn the blower motor on whether the a/c is on or not. I thought it COULD be a bad relay( hoping), I changed with another relay that was exactly the same and it seemed to work for a while. It didn't blow when i turned the blower on or the a/c. I went on a distance trip 2hrs there, 145 back. It worked fine on the way there, but on the way back it blew. When it blows the blower works fine, the a/c light stays on, it just blows "vent air" though. Then it blew again as soon as I put a new fuse in and turn the blower on.
Chris[/quote:27ce57e9c4]
I would suspect a bad clutch. Also make sure you get the correct relay reinstalled in the clutch circuit. Dont want to be causing other problems.
Aug 11, 2006 at 7:07 AM
