97 Grand Am, antilock brake light sensor is on
KANDE87
1997 Pontiac GrandAm, the antilock brake warning light came on last night. What is the cause and suggested fix and is it ok to drive?
Oct 23, 2007 at 9:41 AM
MERLIN2021
  • 17,250 POSTS
The only way to fix anyi-locks so you don't spend more than you have to, is get the ABS codes read by a garage that can! The computer is telling you were to start! Yes you should be able to drive, if the RED brake light is not lit? That would indicate either a leak, or the pads are worn enough to turn that light on!
Oct 23, 2007 at 11:12 AM
